LabWindows/CVI
sound card in labwindows%2Fcvi
urgent!!!!!!!! je     suis  entrain  de   realiser  un  projet  sous  labwindows/cvi  ,  je   veux   un   programme  bien  sur  en  language  C    qui me  permet  de  lire et  recuperer  les   données  numeriser  par un carte  son,et   de  le mettre  dans  un  fichier  .txt  pour  le  manipuler   dans mon  logiciel  labwindows/cv
s'il vous plait  aidez  moi ????????????????:manembarrassed:
EN  ANGLAIS/
Iwant   to  have  the   code  in  C   language    about  data   sound card   ,i  want   to  use  the   data   cardsound  and  to  practise the  data  in labwindows/cvi
Message 1 of 9
(5,962 Views)
Good Day
Do you want to grab the data off of the sound card in CVI
or
Do you want to process the data that is stored in a file after a different application captured the data?
Message 2 of 9
(5,919 Views)
think you  verry  ......................................much:
so that the signal sensed by a sensor, signal will be digitized by the sound card, so for acquirir this signal.
how I read this table value digitize and store in a file.txt to the processing of this signal in my application LabWindows / CVI???????????
please help me
Message 3 of 9
(5,916 Views)
I want an answer as soon as possible if you want because it is essential for my final project study
Message 4 of 9
(5,887 Views)
I await your response is urgently
Message 5 of 9
(5,869 Views)
CVI does not have any native functionality to record sound or pull information from the sound card. Sorry. You may want to look into the Window API to see if there is a function that you are looking for.
http://msdn.microsoft.com/en-us/library/windows/desktop/dd370802(v=vs.85).aspx
Sorry I could not be more help. Good luck on your project.
Message 6 of 9
(5,818 Views)
 has all the national group / instrument about the problem posed above, time passes very quickly and I found nothing about my program, I want a solution,
Message 7 of 9
(5,761 Views)
Hello everyone
I am looking for a function to acquiriri emenant the signal from a microphone connected to a PC
thank you
Message 8 of 9
(5,061 Views)
Salut,
Comme Connor a dit, il n'y a pas de fonctionalité en LabWindows/CVI pour lire et récuperer les données d'un carte son. La meilleur option sera de chercher pour une fonction dans le API de Windows en suivant le lien qu'il vous a donné.
Bonne année!
Message 9 of 9
(5,025 Views)
