LabWindows/CVI
steer panels with buttons
Hello everybody,
I would like to steer with some buttons the appearance of some sub-panels, where one is above the other.
When I push for example "Button_1" the "panel_for_Button_1" is at top.
When I push for example "Button_2" the "panel_for_Button_2" is at top. ...
How can I steer the panels to get one the uppest? Or is that not possible?
thx for answering
(3,212 Views)
I don't know if this is the case, but to make one panel active it is sufficient to use
if( ) SetActivePanel( panelHandle);
or you can use the construct you like best.... anyway, the function is SetActivePanel().
Hope it helps.
(3,204 Views)
I will try it with this function, thx.
(3,202 Views)
Hello Greber.
You may be able to use this also, to control the way the sub-panels overlap:
SetPanelAttribute (panelHandle, ATTR_ZPLANE_POSITION, 0);
From the attribute help:
"Constant: ATTR_ZPLANE_POSITION
Data Type: int
Description: The drawing order of the child panel. The panel with the lowest number (0) is drawn last (i.e., on top).
Valid for child panels only."
Colin.
(3,192 Views)
