LabWindows/CVI
string control flat like text message control
Is it possible to make string control flat like text message control?Is cursor display In text message control possible?
(3,199 Views)
It is possible using classic-style control: you can paint the control frame in transparent color and the final effect is a flat string control. This is not possible with lab-style controls (the standard starting from CVI 7) since their frame cannot be painted other than in the panel background color.
Unfortunately not, as far as I know.
(3,185 Views)
