LabWindows/CVI
string to double
hi,
I'm trying to read spectrum data of an spectrum analyzer and using VISA commands.
I can get trace data as a string in ASCII format in a form in which each double elements are comma-separated.
How can I format this stringto a double array?
thanks a lot
(3,988 Views)
Maybe this can help :
// Split data string into points, convet to double, and output
token = strtok( data, "," );
dataPoint = atof(token); // Convert to double
you can also use Fmt() and Sprintf() for manipulate strings
Kobi Kalif
Software Engineer
(3,986 Views)
