LabWindows/CVI
strtok function returns NULL value
I am using Labwindows CVI to use a experimental equipment. And I made a code but there is a error.
treadbuff value is 0x06818A30 "" However, strtok function returns NULL value so error happens in the last row.
I don't know what is wrong here.
#define MAX_COMM_LEN 128
char *tbuff;
char *treadbuff;
double tcurrent;
treadbuff = (char*)malloc(MAX_COMM_LEN*sizeof(char));
memset(treadbuff, 0x0, MAX_COMM_LEN);
tbuff = (char*)malloc(MAX_COMM_LEN*sizeof(char));
memset(tbuff, 0x0, MAX_COMM_LEN);
tbuff = strtok (treadbuff, "A,");
tcurrent = atof(tbuff);
(4,137 Views)
This is not an error, this is the expected behavior: if you read the manual (which I strongly recommend Smiley Wink ) you'll see that strotk () returns NULL if no token can be found is the string. Since your string is empty it is expected that it returns NULL. You must check the return value on every call to strtok. See timeaxis examples that ships with cvi for a sample use of the function.
(4,107 Views)
