LabWindows/CVI
successful using GetComLineStatus() ?
Has anyone been successful in sensing an externally applied voltage from the PC side of a COM port using GetComLineStatus() ?
Specifically, I would like to sense anytime there -5V is applied to the Ring Detect on a PC COM port, (pin 9, of DB9). kRS_RING_ON or 0x40 is the return status I am looking for when using GetComLineStatus() according to the function panel help. I have also tried using the InstallComCallback and then look for a LWRS_RING, (ring signal detected) event in the callback. Neither approach results in a response. Any Ideas?
Message 1 of 9
(5,093 Views)
What version of CVI are you using?
-Logan S.
Message 2 of 9
(5,079 Views)
CVI5.5.1 I also have newer versions, but I am constrained to use the older version to support existing factory testsets.
Message 3 of 9
(5,079 Views)
Are you designing a multi-thread application?
Logan S.
Message 4 of 9
(5,059 Views)
No, This is a single threaded app.
I have seen some success using the comcallback construct in captureing some com events. However, not the events I am expecting. i.e., I am applying signal ground to pin 5, and -5Vdc to pin 9 (ring indicator). I am expecting to see a LWRS_RING comEvent when I do this, but there is none. I wonder if my PC (a standard dell pentium III desktop, with two standard comports) has defined a ring indication differently than the standard rs232, RJ9 connector pinout for PC modem definition? In any case, a source code excerpt is attached showing three switch statments, each looking at something different: GetComStat(), GetComLineStatus, and eventMask (callback event data)
Message 5 of 9
(5,043 Views)
Sorry for the cryptic responses earlier - there are known issues with the GetComLineStatus() function in multithreaded applications in CVI 5.5 that were corrected CVI 6.0, but as you are working in a single thread that should not be an issue. Would you try re-posting the sample application? For some reason it didn't go through last time.
Message 6 of 9
(5,038 Views)
Logan,
This is not a complete application. Just a function, initially established by a call to InstallComCallback (COMPORT, mask, 0, 0, Comm_Event_Capture_Func, 0); Prototyped as:
void CVICALLBACK Comm_Event_Capture_Func (int portNo,int eventMask,void *callbackData);
If the attachment for the callback function does not go through, let me know, I am somewhat new to using the message boards, I would paste the text of the .c here, but am limited to 5000 characters per post...
Rick
Message 7 of 9
(5,034 Views)
Sorry for the delay... I'm still checking on this for you, I'll post again as soon as I have something. Any progress on your end?
Message 8 of 9
(5,001 Views)
This computer wouldn't happen to be Windows 95 would it?
There is a known bug with the Ring event in W95 that causes it not to be trapped. If CVI wraps this API, or if you are using the API directly, then this could be part of your problem.
http://support.microsoft.com/default.aspx?scid=kb;en-us;137862
Orlan
Message 9 of 9
(4,983 Views)
