LabWindows/CVI
suggested CVI help update on 'Programming with Table Controls '
May I suggest adding a sentence to the 'Programming with Table Controls' chapter, section 'Creating and Deleting Cells' of CVI's help.
After the sentence 'Use the following functions to control the number of rows in a table control....' I would add a hint that the number of rows is also affected by (programmatically) setting the table height.
Now that I found out it's obvious 😉
(3,188 Views)
Accepted by topic author Wolfgang
Hi Wolfgang,
I think you might be misunderstanding that sentence in the help. It is not referring to the size of the table, in terms of how many rows fit in the table. It's actually referring to how many actual rows are in the table. And the total number of rows in the table is definitely not affected by the height of the table.
Luis
(3,178 Views)
Hi Luis,
you are right! I was confused by a table that was larger than I thought, see the discussion here.
Thanks!
(3,173 Views)
