LabWindows/CVI
syntax coloring of numbers
one more comment  Smiley Wink
I suggest to include the minus sign of integer and real numbers in the syntax coloring. In the example shown below the integer is -1, not 1....
(3,636 Views)
Wolfgang,
this looks like a reasonable feature request. Because of that, i recommend you to post feedback like this in the CVI idea exchange forum. I've seen that you already used it before, so you should be well with that 😉
Norbert
Expert: Geometry
(3,597 Views)
Hi Norbert,
of course I can do so, no problem.
In the past, I distinguished between 'unexpected' behaviour and missing feature, the former reported here and wishes over there. In this forum, I would hope for a CAR which in my idea might be faster...
I guess I simply was too polite Smiley Tongue, I should have been more courageous and call this behaviour a bug, because -1 is a valid integer but syntax colouring does not work for it Smiley Wink
The same is true for 1.0 and -1.0.
Interestingly, the minus in 1.0e-6 is displayed correctly Smiley Very Happy
(3,592 Views)
Accepted by topic author Wolfgang
as already discussed, I filed a CAR regarding the issue you reported: CAR-679688.
Best,
Ezer
(3,511 Views)
Thanks Smiley Happy
(3,505 Views)
