LabWindows/CVI
syntax error: found 'integer constant' expecting '}'
I just added Spectral Measurement Toolkit 2.6.2 to my project to correct link errors.  An error, syntax error: found 'integer constant' expecting '}', is being generated by the typedef enum for AnalysisLibWindowType in advanlys.h.  The syntax looks correct.
(5,854 Views)
Hi Herbert,
Can you post a screenshot of the error and the part of the syntax to which it is referring?
Travis Ann
Customer Education Product Marketing Manager
(5,834 Views)
Accepted by topic author herbertwatson
Error was caused by creating a type def with the same name as a previously defined variable or constant.  The problem had nothing to do with the syntax error generated.  Thank you for your help.
(5,824 Views)
