LabWindows/CVI
system colors override
Greetings,
I would like to override the conform to system colors attribute on a panel for a single control on a panel
Essentially i need to make one control the BRB (big red button).
However, if I try to make it red I have to uncheck conform to system colors which leads to other problems.
The reason that I want to do this on the source panel is because when I use the SetCtrlAttribute function to change the color, sometimes the color changes back to the standard gray.
There is no place in my code where a color is changed to gray on any other SetCtrlAttribute function call.
That leads me to believe that I am not inadvertantly changing the color back by having a bug with either an incorrect panel handle or control number.
So I assume that CVI is just changing the color back to the source color on its own.
Does anyone know a way of doing this?
(3,189 Views)
You can override system setting for individual controls by calling SetCtrlAttribute with ATTR_DISABLE_PANEL_THEME attribute: see here. Next you can set the button color with ATTR_CMD_BUTTON_COLOR attribute.
(3,166 Views)
