LabWindows/CVI
system command
Dear all friends.
 I am currently using CVI 2009 with sp1. i have a problem when i using system command in a dll file. some of times . this command cause the FATAL error. pls refer to attached screenshot .  the length of commandline is 1024. so i do no think this is the buffer length issue.
do somebody have this problem in before. or any way to know  the proper way to find the root cause ?
Thanks in advance!
B.R
Gerry
Message 1 of 1
(3,230 Views)
