LabWindows/CVI
system socket error (-4) while doing FTP
Hi I am trying to FTp some file to the Unit Under test using labWin FTP function. While debugging, everytime I execute this call, labWin gives me the following error: Funtion InetFTPSendFile:(return value == -4(0xfffffffc)) System Socet Error. I am not sure what is happening. I used to use it on other products, but I have no idea why it is not working on this one. Any suggestions?
Thank you.
(4,012 Views)
One more thing, I have tried to FTP this file using the regular command prompt and it works just fine and also I am able to ping it successfully. Any suggestions?
Thank you.
(4,006 Views)
Hi qsa301,
Have you tried the CVI shipping example called "ftpcInt.cws" ?  This uses the InetFTPSendFile function.  Trying the example program will help to determine whether the error is due to coding or connectivity problems.
Jessica
Product Support Engineer
(3,971 Views)
Thank you very much Jessica for your reply. I actually had a USB to ethernet adapter connected to my computer and that causing all this mess to happen. I disconnected it from my computer and the FTP started to work again. Thank you again for your help.
(3,929 Views)
