LabWindows/CVI
tab control bug in conversion from uir to code
and i tried to use the solution: use 'Embed project .UIRs' option in the Target Settings dialog.
It dosn't work:  I move dll to another folder, call it from teststand and it still requesting uir component.
May be i should change component file name passed into LoadPanel function??
Thank you
Message 1 of 1
(3,176 Views)
