LabWindows/CVI
table button set visible
Hello, I'm trying to change the visibility / dimmness of a cell button inside a table.  From what I could gather, this was the proper method:
SetTableCellRangeAttribute(panel,table,VAL_TABLE_COLUMN_RANGE(column),ATTR_DIMMED,TRUE);
 But I get a NFRTE: "The attribute passed is not valid"
How would I go about doing this?
(4,099 Views)
Accepted by topic author ElectroLund
Hello ElectroLund,
You need to use ATTR_CELL_DIMMED instead of ATTR_DIMMED in the call of SetTableCellRangeAttribute()
If you use the function panel it is easier to get the right parameters
(4,085 Views)
Thanks!  Yeah, I need to start using the FP more.  I'm not in the habit...
(4,072 Views)
