LabWindows/CVI
table column to small
hello,
i read data from a xml file and display it in a table. the columns are to small for the data and the table doesn't autosize.
is there a way to set the size of each column??
best regards
markus
(3,608 Views)
You can use
SetTableColumnAttribute (panel, table, columnIndex, ATTR_SIZE_MODE, VAL_USE_EXPLICIT_SIZE);
SetTableColumnAttribute (panel, table, columnIndex, ATTR_COLUMN_WIDTH, pixels);
where <pixels> is the desired column width.
(3,600 Views)
hello,
your code doesn't seems to be LabView code.
markus
(3,588 Views)
Sure: you're in CVI forum! Smiley Wink
Maybe it's better you post your question in the LV forum where you'll surely find more help.
Anyway, I'll try to set the width of a cell in a column via a table property node (properties active cell + cell width). But it's possible that there is a more efficient method.
Message Edited by Roberto Bozzolo on 09-26-2005 09:12 AM
(3,585 Views)
