LabWindows/CVI
tabs pages
I created a main panel housing the 1 tabs control and a numeric control within this tabs. During run time, I copy the tabs page to 9 more pages, so each tabs page contain the numeric control within it. I need help how to program in CVI to set & get the values from the numreric control from these different tabs pages. Thanks.
(3,841 Views)
You should use the function GetPanelHandleFromTabPage to get a panel handle for the tab page, containing the numeric control you want to access. Then simply use the GetCtrlVal and SetCtrlVal functions to set and get the values from the numeric control. The parameter 'panel' of these functions should be the panel handle you got from the GetPanelHandleFromTabPage function.
Message Edited by Wim S on 04-26-2006 05:27 PM
(3,834 Views)
It works. Thanks so much.
(3,815 Views)
Thanks for rating my message Smiley Very Happy
(3,799 Views)
