LabWindows/CVI
tabulator problem
Hello
I'm a user of CVI 8.0.1. I need your advice how to remove/solve a small problem.
I've build a GUIsoft with many hot fields. When I like to jump between these fileds,
I want to use tabulator what makes my soft more user-friendly, the coursor doesn't
jumps I want. How to set up  my soft  or set priority for given fields  to jump between
fields in a specific way.
CKONIO
(3,438 Views)
In the uir editor, click menu item Edit->Tab Order. This will allow you to choose which order the controls are highlighted when you use the Tab key.
JR
Message Edited by jr_2005 on 07-17-2007 11:38 AM
(3,437 Views)
This is it.
Funny, I've never use it before.
Thanks a lot JR.
CKONIO
(3,431 Views)
