LabWindows/CVI
testinview
I use Clemessy's TestinView (TIV), and to creat GUI I use Labview, a *.vi and TIV communicate using input and Output clusters, Now I would like to use Labwidows/CVI to creat a GUI for a special application, how would TIV and the labwindows application communicate. .
could someone for Clemessy ansewer my question please.
 thanks
Message Edited by thsalam on 11-05-2008 02:57 PM
(5,824 Views)
As describe in the TIV User Manual it's possible to interfacewith TestInVIEW to different types of GUI : LabVIEW GUI and .NET GUI.
At this time it's not possible to interface LabWINDOWS/CVI GUI  with TestInView. It's not due to an incompatibility but we never had the request.
So I would have several question,
What is you're company ?
Which version of TestInView do you use ?
Why do you need LabWindows GUI ?  Do LV or .NET GUIs could be conveniant for your application ?
Pierre R...
Certified LabVIEW Developer
(5,795 Views)
Accepted by topic author thsalam
Thank you for your quick ansewer .
I am a consultant at Renault Technocenter, I use theTIV 4.1.2h, I need to creat an application that creats GUI that can be interfaced whith TIVusing Labview, I am currently exploring possible solution.
I will try with .NET
(5,789 Views)
If you have any question or need some tips and tricks. Don't hesitate to contact us, we will be pleased to help you.
Ask to Omar Sahraoui from Renault the contact reference of Clemessy TIV engineering team.
Pierre R...
(5,780 Views)
Hello p.Roth,
You are not right .. Boooo ! .. TIV can be accessed from Labwindows CVI using it's dotnet api !
This has already been done by RSA. (TIV vision addon)
To interface CVI to TIV you can use the set/get api like the one used by TestStand.
Manu.net
Manu.net
(4,945 Views)
