LabWindows/CVI
thread setup timing takes way too long
Thread setup takes too long.
I have a summing loop that I divided into multiple threads.  But it took 30 milli-secs to get the threads started.  I could do the whole loop in a single for() in much less time.  I followed the NI example almost exactly. Setting the priority made almost no difference.  Does something in a Windows7/8 setting need fixing?
tx
Matt
(4,411 Views)
Hello scudieremb,
What version of LabWindows/CVI are you using? Are you noticing a slowdown compared to another OS, or to another runtime?
= Nelu F. || National Instruments.
(4,404 Views)
In order to avoid the overhead of starting the threads in the exact moment you need them, you could try an alternative approach based on thread safe queues: see this help page
At program start you can create threads and thread safe queues, next in the thread callback simply setup the callback associated to the thread queue with CmtInstallTSQCallback and wait for events in the queue. The producer thread then sends data to the queue and the separate thread reads them in the callback and operate on data.
(4,382 Views)
