LabWindows/CVI
timer interval
I need to count and add up each each elapsed second in my timer. this seems not to work , it is just outputting 1,1,1,1, ... but I need 1,2,3,4,5.....
int CVICALLBACK timer1 (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 static double    time1;
 double time2;
 double interval = 0;
 switch (event)
  case EVENT_TIMER_TICK:
    time1 = *( ( double * ) eventData1 ); // current time
                time2 = *( ( double * ) eventData2 ); // time elapsed since the last EVENT_TIMER_TICK callback.
    interval = interval + time2;
    printf("ammmmmmm");
    printf("Interval = %.0f",interval);
   break;
 return 0;
(3,884 Views)
Well, your variable interval is local: every time the timer callback is called, it is reset to zero -> use a global declaration instead
(3,880 Views)
Thanks, that helps.
(3,875 Views)
