LabWindows/CVI
tooltip multiline error
Using the attributes panel for controls in the uir editor, trying to use the tooltip editor i get Buffer error message
same problem as reported here, but this is occuring in cvi2015,
http://forums.ni.com/t5/LabWindows-CVI/tooltip-bug-quot-buffer-passed-was-too-small-for-the-operatio...
(4,122 Views)
Hello john_cvi_user!
Thank you very much for your post!
This is a known bug and our R&D is planning on changing it. Unfortunately, this is still an active bug, meaning that the R&D is still working on it. As Johannes_T mentioned on the linked forum post, the bug ID is #492787.You could check the readme file of the new releases of  LabWindows/CVI to verify if this bug has been fixed.
Please accept my apologies for any inconvenience.
There is a workaround if you need to add multiple lines where you can:
1) Insert a newline character (\n) in the string of the Tooltip Text field in the Attribute Browser
2) Programmatically set the attribute
I hope this information is useful and you will be successful at your application.
Kind regards,
Vasileios
Vasileios T
National Instruments UK&Ireland
(4,099 Views)
