LabWindows/CVI
tooltip with duplicated control
I associate tooltip with a control and then I duplicate this control n times and I associate tooltip with each of these controls. None of the duplicated controls have their tooltip, and, the original control has the tooltip generated for the last created duplicated control. Is there a bug or do i something wrong?
Thanks.
(3,082 Views)
Hello yc,
There seemed to be something going on here, and I have filed a report with our R&D department to look into it. As a workarond, you should duplicate the control before associating a tooltip to the control. If you duplicate the control n times, then associate tooltips with your duplicate controls and with your original control, and you should see the correct behavior.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,067 Views)
