LabWindows/CVI
trouble with launchexecutable() file path name
I am using launchexecutable() to open a .ini file in notepad.
If i specify the path name as launchexecutable(NOTEPAD.EXE  D:\\Documents and Settings\\T0128779\\Bureau\\filename.ini) the file opens perfectly. The problem i have is that i have a string that stores the path name but without two slashes between for example the string contains the path name as D:\Documents and Settings\T0128779\Bureau\filename.ini
launchexecutable doesnt seem to work with this string. What am i doing wrong?
Rohit
Message 1 of 8
(4,685 Views)
just to add the string is created using GetDir() and MakePathName(,,)
so my question really is will launchexecutable() work with a path name that has only one slash between directories and if not how do i add a second slash? thanks a ton;
Message 2 of 8
(4,678 Views)
It's supposed to work with the string, see here
What's the error you're getting?
Message 3 of 8
(4,671 Views)
Hi Wolfgang, thanks for the link. I used Wendy's method and now my string has two slashes but still isnt working.
When i pass the path through the string i get the msg 'Cannot find file filename.ini Do you want to create it?'
But when i pass the path directly without the string the file opens. Could it be the quotes "" in the string?
Message 4 of 8
(4,667 Views)
Yes, in the argument of LaunchExecutable you should enclose the file name in quotes because it contains spaces.
Message 5 of 8
(4,665 Views)
yes this is how i have it..
launchexecutable("NOTEPAD.EXE stringname")
but the stringname also has the path in quotes is that the problem?
Message 6 of 8
(4,661 Views)
Accepted by topic author sinnas
This will not work. You should have a look at the CVI examples using LaunchExecutable. There you will find how to do it:
sprintf (tempstr, "Notepad.exe %s", stringname);
LaunchExecutable (tempstr);
Message 7 of 8
(4,659 Views)
oh great thank you!!
Message 8 of 8
(4,657 Views)
