LabWindows/CVI
troubles about using goto statements
my CVI is CVI2013.
in a function called Send(),which is defined myself,i used goto statements to jump out of switch statements inside of for statements.
which is showed below:
int Send()
       for(...) //the first for
             if()//the first if
                   for()//the second for
                        switch()
                                  case 1:
                                  goto         Label1;
                           }//end of switch
                   }//end of the second for
             }//end of the first if
   Label1:  continue;
     }//end of the first for
when i compiled it ,it showes:
" 485, 49 error: use of undeclared label 'Label1'",
"624, 1 error: use of undeclared identifier 'Label1'"
why?
(4,871 Views)
Accepted by topic author winter1970
With the risk of being simplistic, I would double check that a true colon is used after the label definition and not a semicolon: it's something that sometimes happens to me, they are so similar!
(4,812 Views)
in my function, there is not only one "goto Label1",may be the reason of coming faults?
int Send()
             if()//the first if
                        switch()
                                  case 1:
                                  goto         Label1;    ///    Number1
                                  break;
                                 case 2:
                                 goto      Label1;       /// Number2
                           }//end of switch
                  goto   Label1;         ///Number3
   Label1:  continue;
similarly above, only defined one Lable "Label1", but have some calling"goto Lable1". Maybe it is the reason?
(4,804 Views)
You may have as many goto statements as you want, that's not the problem.
But that "undeclared identifier" error on line 624 probably points exactly to Label1: line which in my hypothesis is not correctly written (e.g. the colon is missing or is replaced by a semicolon)
(4,797 Views)
Why don't you simply write continue instead of goto Label1.
goto's are not the best coding practice.
S. Eren BALCI
IMESTEK
(4,783 Views)
Can you copy and paste the exact code?  There may be something wrong in the code that's not showing up in the snippets you've posted so far.
(4,734 Views)
last time,when i met the troubles when using "goto",i used flags instead of 'goto',and it works.
today,when i see your replys,i used "goto" to recode the source, and now the troubles never appeared.
so, it seems to be very confused me.
maybe, some wrong syntax caused it.
i use tortoiseSVN to record my project,and i forgot to save last "goto" codes last time ,and now it cannot to be reappeared.
thans all.
(4,715 Views)
