LabWindows/CVI
uir to C-code converter
Is there a way to convert a UIR file to code that generates panels with the wanted controls on it? That way it wouldn't be necessary to put the uir file in the software release, and it would also prevent others with CVI installed to mess with the uir file.
Also one time I changed  the names of all the menu callback functions, and it was quite a hassle to edit this in the menu. A code where you can simply replace all the text with shift-F11 would have been really handy at that time. Or did I overlook something? (CVI 6)
(3,436 Views)
Try the UI to Code Converter (Tools >> UI to Code Converter). This should give you what you need.
Bilal Durrani
NI
(3,426 Views)
Oops.. sometimes it pays to check out the menu options dunnit? 😉
Thanks for your answer.
(3,422 Views)
You can also embed the UIR as a resource in the EXE file, in CVI 7.1.
Martin.
Martin
Certified CVI Developer
(3,404 Views)
