LabWindows/CVI
un-Release Window, how?
I am using LabWindows/CVI 8.  From the help file I see...
Window»Release Window Use the Release Window command to remove the window from the Window Confinement Region.
My question is, After I do this how do put the window back into the Window Confinement Region?
(5,769 Views)
In the released window, go to the menu and select Window > Confine Window.
(5,763 Views)
The window I released (Source Code Browser) does not have a Window menu option.
(5,754 Views)
Ok - no so obvious. Smiley Happy
After a moment of panic, thinking I be stuck the same way you are,  I found that right clicking on the tab or column headers of the released window offers up a "Confine Window" option.
--Ian
(5,750 Views)
Thanks!
(5,744 Views)
useful, thanks !
(3,583 Views)
