LabWindows/CVI
unavailable when debuggee is not suspended MSG
Hi ,
I'm trying to use the CVI Resource Window but every time this msg appear at the window
I'v tried to search for an answer in the forum but with no luck...
Thank You for your help
Kobi
Kobi Kalif
Software Engineer
(4,009 Views)
Try setting a breakpoint in your code. It should work then. After the program has finished, ideally there should be no more resources - except that you have a memory leak...
(4,007 Views)
Thank you for the response , There are no leaks
But Is it the only option ? it's not so comfortable....
Kobi
Kobi Kalif
Software Engineer
(3,995 Views)
Of course, you have to enable it in the Windows/Resource Tracking menu
(3,992 Views)
