LabWindows/CVI
undefined references
Test Executive v5.0 was uninstalled, then when re-installed,when trying to load a sequence it displays
"unable to load test 'current' c:\cvi\tx20\'v12am.obj' (undefined references)".
The project runs ok from labwindows\cvi but not using test
executive version 2.0.1.
Have checked directory structure as in p5-7 of test exec manual,everything seems to be in place.
Anybody got any ideas?
(3,065 Views)
Hi Dab,
When uninstalling/deleting the Test Executive files, u might have removed the source/obj files. Try generating all the obj files again (rebuild with 'o' option enabled for source files) from the same project and then try executing your Test Exec exe.
Hope this helps.
thanks
COM_ROCKS
(3,043 Views)
