LabWindows/CVI
unhandled win32 exception ?
Hi All,
I have been getting this error for sometime in my code. I am guessing that this could be because of memory leak. How do I get to the error ? Is there any debugger that will help me get to the cause of the error ? I am unable to get to the point where there could be possible memory access problem.
Kanu
(3,064 Views)
Hi Kanu,
You could try using the Resource Tracking window to monitor memory allocations and deallocations.  To enable Resource Tracking, go to Options » Build Options... and choose the Extended debugging level.  Then go to Window » Resource Tracking to bring up the Resource Tracking Window.
More information regarding Resource Tracking can be found at the Developer Zone article Memory Leak Detection with LabWindows/CVI .
Brandon V.
Applications Engineering
www.ni.com/support
(3,052 Views)
