LabWindows/CVI
unknown type name "intptr_t" when convert project from CVI5.5 to 2013
I am getting some compile error messages when trying to convert the previous project from 5.5 CVI to the current 2013 Version.
"toolbox.h"(762,9)    error: unknown type name 'intptr_t'
  "toolbox.h"(1251,42)    error: unknown type name 'CVIAbsoluteTime'
toolbox.h is a read only file, and I couldn't change anything at this moment.  Does anyone know what cause this issue? and how could I solve it?
Message 1 of 8
(6,359 Views)
First of all I'd check that the correct version of the toolbox is in use: if you have opened the old project in the new IDE, you could be pointed to the old library.
Message 2 of 8
(6,354 Views)
Hi RovertoBozzolo,
Thank you for the help, I double checked and guess I am using the new header files, which is pointed to C:\Program Files (x86)\National Instruments\CVI2013\toolslib\toolbox
at the meantime I am also getting error messages showing: 'CVIAbsoluteTime' .
Probrabaly causing by the same reason.
Message 3 of 8
(6,348 Views)
I was intending the whole Toolbox,  not only the header file. Depending on how it is is loaded, you can find it listed either in Instrument or in Library menu.
Message 4 of 8
(6,339 Views)
Do you mean include the .fp files in the library menu?
I include the file both under Library and the Instrument Menu.
But still I am getting the message indicating I need to insert #include "toolbox.h" in my code
after I insert the code, the error message still the same:
Message 5 of 8
(6,326 Views)
The situation is not clear!
intptr_t is defined in cvidef.h, while CVIAbsoluteTime is defined in utility.h: none of them is defined in toolbox.h, even though they are used in it.
You could try deleting all #includes from the source and let CVI add all necessary files by itself.
Do you get the same errors while running a shipping sample? Possibly one that makes use of the programmer's toolbox (e.g. the infile example that you can find in <CVISamplesFolder>\toolbox\ini.cws).
Message 6 of 8
(6,319 Views)
Was this problem solved, did deleting the #includes worked or some other kind of solution, I am having similar issue with the IniText instead of intptr_t.
Please let me know.
Riddhi
Message 7 of 8
(4,113 Views)
This forum post is 3 years old, so it might benefit to make a new one if the original person doesn't respond. Just FYI 🙂
Francine P.
Applications Engineering
Message 8 of 8
(4,103 Views)
