LabWindows/CVI
unrecoverable error
Eversince I started using CVI 7/7.1 I see this kind of error left and right. and so far I was ignoring these errors. I just restart CVI and start my work. but I think I reached a limit so here is one screen shot.
I never had this problem in 6.0. I used 6.0 for about 1.5-2 years and it was excellent.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Message 1 of 12
(5,027 Views)
Does this happen with a particular project or with everything you have tried? Is there a particular set of steps that cause this to happen?
Bilal Durrani
NI
Message 2 of 12
(5,000 Views)
This happened when I right clicked on Event Function for help and try to copy
int CVICALLBACK FunctionName(int reserved, int timerId, int event, void *callbackData, int eventData1, int eventData2);
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 3 of 12
(4,990 Views)
Did this happen with a particular function panel or from a UIR? You mentioned an event function, but I'm not sure which one you are referring to.
Bilal Durrani
NI
Message 4 of 12
(4,959 Views)
Function panel (New async timer) is shown in attached picture. (First message). Event function of new async timer function.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 5 of 12
(4,955 Views)
Hello Sheetal,
I don't seem to be able to reproduce this error.  Is this problem readily reproducible?  As in, do you get this error every time you try to copy the help documentation from the Event Function parameter of the NewAsyncTimer function panel?  Also, regarding your setup, which operating system are you using?
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
Message 6 of 12
(4,937 Views)
No. it is not repeatable.
But I have noticed that these types of errors occures only after I work on CVI for a long time (30 min+) I will post more of these errors when I see them.
My OS is XP.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 7 of 12
(4,924 Views)
Here is one more interesting screen shot. No matter where I click on window this would not go away. I had to close and reopen window to take care this.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 8 of 12
(4,909 Views)
Hello Sheetal,
If both of these issues are occuring in the same workspace and project, one or both could be corrupted.  You might try creating a new project and workspace with your source, header, and UIR files to see if this helps both issues.
Thanks.
Wendy L
Message 9 of 12
(4,904 Views)
Wendy,
they are different projects.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 10 of 12
(4,800 Views)
