LabWindows/CVI
unrecoverable internal error at 001B:100E5A69
Everything was fine working with a single workspace containing 7 projects. But now when I try to "switch" between projects  (selecting one as active project) I got the message "Unrecoverable Internal Error at 001B:100E5A69" and then CVI crashes...
I'm using CVI 8.1.0.
Any help will be really appreciated.
Delfino
(2,973 Views)
Hi Delfino,
We definitely want to get to the bottom of the crash you are seeing but ut in order for us to be able to investigate it, we will probably need to be able to reproduce the sequence of events that led to the crash. Can you tell us a bit more about what you were doing when thhis crash happened?  And if you preform that sequence again, does it still crash?  If you can reproduce it consistently, would it be possible to provide us with a sample workspace and projects that exhibit that behavior? Does this happen on multiple machines? With different versions of CVI?
Also, it would help us if you could provide us with a crash dump. See this post for instructions on creating a crash dump.
Best Regards,
Jonathan N.
(2,954 Views)
