LabWindows/CVI
unresolved external symbol _LinearFitEx@44 referenced in function
I get this error when building in VS 2010 as a converted CVI project.
It builds without errors in CVI using LabWindows/CVI project.
(4,606 Views)
LinearFitEx is a function from the Advanced Analysis library. As far as I know you have to buy/install Measurement Studio to make this library available for VS.
(4,599 Views)
You don't need Measurement Studio, but the analysis libraries have to be included in the project, one way or another. In modern versions of CVI they (analysis.lib, regenlys.lib) can be found in:
%ALLUSERSPROFILE%\National Instruments\CVI<version>\extlib\msvc (32-bit version) or
%ALLUSERSPROFILE%\National Instruments\CVI<version>\extlib\msvc64 (64-bit version)
Martin
Certified CVI Developer
(4,593 Views)
Thanks for the help
The VS project does include reganlys.lib but not analysis.lib.
Also only reganlys.lib is in the path specified below.
I don't think it is an installation issue since it builds as a labwindows/cvi project.
(4,584 Views)
So have you tried including analysis.lib, as I suggested?
Martin
(4,555 Views)
I don't have analysis.lib only reganlys.lib
(4,546 Views)
There is one thing I do not understand, how can you use a function from the Advanced Analysis Library without having the Advanced Analysis Library?
(4,539 Views)
