LabWindows/CVI
updatiing the sequence file in CVI
Hi all
We have source code developed in CVI, and the code is used to test various functionality of the product with the help of sequence file,
I have one issue any help greatly appreciated,
I would like to abort the test sometimes in between before completion of all the tests, whenever I abort the test , it has to perform one specific test.
Eg: there are 1-30 tests whenever I abort the test (Say test 5), it should perform 25th test and complete as 25th test has few type settings of the product , I am aware there are something to change in sequence file.
(4,244 Views)
Hello HussainHTS!
Is your question more related to TestStand and TestStand sequence files?
If so, please use the dedicated NI TestStand Discussion Forums.
Best regards!
- Johannnes
(4,137 Views)
