LabWindows/CVI
usb communication
hai,
      i have controller with rs232 communiction. for that controller, i have source code for communicate between rs232 com port and apllication. The application written in labwindows/cvi5.5 . communication performance ok. But now i have advanced version of that controller with USB communication type. Controller functions remains same. only the communication port is different. Now i want to program to communicate that controller through USB(universal serial bus). along with the controller i have kit of USB driver also. only thing, i have to send and receive data through usb port. for that i have to program.  Dont worry about what type of controller. controller only send and receive data. and onemore thing is, controller will be serial input/output.Anybody can help me for this? thank you in advance.
(3,178 Views)
Please check what USB drivers are supposed to do with the controller. There is the possibility that the driver installs a virtual com port over the usb channel, in which case you have to do absolutely nothing except setting the appropriate port number.
(3,177 Views)
thanks for ur reply. actually i want to know how to go rs232 to usb communication in labwindows cvi5.5. what are the libraries i have to use for usb communication? and also, In labwindows help menu,i have seen only rs232 related helps, nothing is there about usb communication. how can i get that?
(3,164 Views)
