LabWindows/CVI
use of ftime for time less seconds usec timeb.h
I try to use ftime in CVI 8.0. I get an conflict in the headerfiles between timeb.h and time.h from CVI.
It tells me that   "time.h"(61,28)   Redeclaration of 'time_t'. time.h is called in #include <ansi_c.h>.
The timeb.h file I get from my Visual C++.net 2003. I have set up a project in VC that runs without problems.
How can I avoid the conflict with the time_t declaration.
Thomas
(4,072 Views)
Dear Thomas
You probably have 2 options to make that work:
 1. tweak your program using #undef such that it doesn't throw that error; this might be cumbersome, though, because I'd expect other similar errors to show up;
 2. not include ansi_c.h; this approach is much easier, because most of the ANSI-C functions can be replaced by CVI functions anyway.
Best regards
Philipp R.
(4,019 Views)
Is it possible to leverage timeb.h (and it's functionality) from LabWindows/CVI directly?  If not, does LabWindows/CVI support comparable functionality?
(2,943 Views)
