LabWindows/CVI
using CWgraph for bar graph with labwindows
i'm trying to use the activeX control CWgraph in Labwindows for displaying a bar graph but I don't understand how this control works. In my bar graph, I want that each bar have the same size and have the same space between them and all I obtain is a graph with bars of decreasing size with no space between them. Can anybody help me on this? Thanks.
(3,354 Views)
To display a bard graph, you have to configure the plot attributes. The attribute LineStyle must be set to LineStepXY to have steps. The attributes FillToBase and LineToBase must be set to VTRUE.
There is no way to insert space between each bar, nevertheless ou can insert values in your data array.
You will find an example attached to this thread.
(3,311 Views)
