LabWindows/CVI
using Excel_RangeGetItem() and Excel_RangeSetItem() in CVI 6.0
I borrowed the usages of these two functions from Excel200dem.prj. But the cell range indexing is acting weirdly. If I want to access to cell range A1-A700, A2-701, A3-A702, and A4-A703, I'm actually accessing to ranges A1-A700, A3-A702, A5-A704, and A7-A706 respectively.
You may suggest me to use Safe Array. I'm now using it to write the data, but when I try to read, it seems to only support 2-dimension reading (there is a function CA_Get2DArrayElement(), but no function like CA_Get1DArrayElement() ).
Pls somebody can help either of the problems. Thank you very much.
Jason
(4,088 Views)
I've attached two files that contain passages of my program that deal with reading and writing data in Excel.
Concerning your "2Darray-problem" there is a trick: just create a 2D array with 2nd dimension=1, so that it is in fact a 1D array but can be handled as a 2D so that you can use the provided functions in a normal way.
Remark: I'm using ExcelXP (Object Library 10.0) while the CVI samples have been programmed under Excel2000 (Object Library 9.0). So some functions may look different.
(4,088 Views)
