LabWindows/CVI
using IMAQ functions
Dear Users,
I use CVI/2013 together with NiVision library.
For an image I use imaqHistogram to get the histogram parameters from the image.
The image is indeed of type Image and not an array that contains the image-pixel values.
Now I want to display the histogram.
How can I easely do this?
My aim would be to display the histogram into a EditGraph of a Panel.
I found a example for using CVI-native function "Histogram".
With this I can define a "x_array" and "y_array".
With this I can use PlotXY();
However using the "imagHistogram"-function I am struggling to find out the "x_array"and "y_array"
Thank you,
Philipp
(3,278 Views)
..think i found the solution:
// in h.file
int x_array[BitDepth];
int y_array[BitDepth];
HistogramReport * Hist;
// in c-file
Hist = imaqHistogram(....necessary entries....);
// creating x-array
for(i=0; i < BitDepth; i++)
       x_array[i] = i;
// creating y_array
for(i=Hist->min; i < = Hist->max ; i++)
       y_array[i] = Hist->histogram[i];
panelHandleHist = LoadPanel (0, "my.uir",PANEL_HIST);
DisplayPanel(panelHandleHist);
PlotXY(panelHandleHist, PANEL_HIST_GRAPH, x_array, y_array, ... );
(3,256 Views)
