LabWindows/CVI
using a C++ dll(with classes)in CVI
I actually have a dll containing classes (dll from Visual Studio.NET). How can call functions contained in these classes with CVI7.1?
Thanks a lot for help
Arnaud2404
(3,098 Views)
Since CVI is an ANSI C compiler, you can't directly call any functions that require classes as parameters or that require you to instantiate a class before you can call a member function. The DLL functions may use classes internally, as long as the class is not your interface to the function. Many DLLs written with classes export C wrapper functions that can be called from a C compiler. If your doesn't, you'll have to use Visual Studio.Net to create your own wrapper functions. Those functions must pass all parameters acceptable to ANSI C, but may use classes internally.
(3,098 Views)
