LabWindows/CVI
using c++ dll in CVI
I'm using C++ dll for Ethernet to I2C communication. The problem is that when I add the *.lib and *.h files to my project,
I get a lot of errors. The most strange on is that the compiler doesn't recognise "extern "C"..."
I would be glad if someone can help me with this problem.
Barak
(3,312 Views)
You may have aready seen this post, which should point you in the right direction.
JR
(3,295 Views)
