LabWindows/CVI
utility library error string function?
I've been working on an Error Handler library, culled mostly from these wonderful fora (Roberto!).  I can't seem to find an error code string generator for the functions in the Utiltiy Library though (in particular, functions like RenameFile, CopyFile, GetDir, SetDir, MakeDir, all the file i/o functions).
Most of those make mention to negative error types with some plain text explanations.  But there's no mention of a nice code-to-string converter function, as there is in other libraries.  For instance, for the RS232 library, there is GetRS232ErrorString.  For the Formatting & I/O library, there is GetFmtIOErrorString.
Am I not seeing it somewhere?  Inside the Utility library, there is a multithreading error code function called CmtGetErrorMessage.
(5,269 Views)
Greetings,
There doesn't seem to be a function in the Utility library just like the other ones you mentioned, but the following article may help in handling the errors yourself:
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/programmerref/errorchecking/
And for the error codes themselves, you can search by function:
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/libref/cviutility_library_function_tree/
Brandon V.
(5,237 Views)
Darn!  I was afraid of that, just from my own exploration.  I'm somewhat surprised.  Seems like a big omission, given that most of the other libraries have their own string errorCode decoder.
Oh well, I'll make my own.  Thanks.
(5,216 Views)
Accepted by topic author ElectroLund
You're right: the Urility Library does not incorporate a function that translates error codes to a meaningful text. I suppose this is due to the fact that error codes partly overlap, so a unique function could not be used.
Just as an example, error -1 means File not found in almost all file I/O library functions, but it translates to No files found matching the search criteria in GetFirstFile () , to No more files in GetNextFiles () and Invalid Parameters in MakePathname ().
Another example: error -2 means GetFirstFile must be called before if returned by GetNextFile (), and Resulting pathname too long if returned by MakePathname ().
And this considering only File I/O section of the library!
While developing my own toolbox of utilities, I have created the following function, which I know is far from perfect and covers only file I/O functions:
char * CVIFUNC GetULibFileIOErrMsg (int error)
// Messages associated to error codes returned by functions in File Utilities class in Utility Library
	switch (error) {
		case 0:	return "Success";
		case -1:	return "One of the path component not found";
		case -2:	return "Resulting pathname longer than 260 chars";
		case -3:	return "General I/O error occurred";
		case -4:	return "Insufficient memory to complete operation";
		case -5:	return "Invalid path";
		case -6:	return "Access denied";
		case -7:	return "Specified path is a directory, not a file";
		case -8:	return "Disk is full";
		case -9:	return "New file already exists";
		default:	return "Unknown error";
	return NULL;
(5,211 Views)
