LabWindows/CVI
vbaiOpenInspection timeout error
Hi everyone,
I've got a problem when I try to open a vbai project with vbaiOpenInspection. It return VBAIErrorEngineTimeout error.
In the project there are two acquire images step from two different cameras. If I use only one camera the vbaiOpenInspection function works but it is very slowly.
I'm using 20 Megapixel Baumer cameras
Is there a Engine Timeout parameter to change? Is there some settings that I can change to speed up the inspection opening?
Thanks to all.
Message 1 of 1
(1,571 Views)
