LabWindows/CVI
vector to matrix tranformation
Hi, I have made up a little example that reads a table from the UIR, transposes it and displays data on an output table.
This is done by reading data in a single array and passing it to Transpose.
An interesting trick of tables is that you can obtain the same effect by reading data in column major order and writing them back in row major order (or vice-versa): this method also is included in the example.
You could think to use it in your app duplicating the original table in a new, hidden one to use only for transposition of the matrix: read transposed data back from the new table and discard it afterwards.
Message 11 of 13
(1,015 Views)
Hi cat87,
Something like this should work for what you are doing.
    int vector[100] = {0};
    int matrix[10][10] = {0};
//Fake Data
   for (int hundred = 0; hundred<100; hundred++)
        vector[hundred]=hundred;
//Into Matrix
for (int tens = 0; tens < 10; tens++)
        for(int ones = 0; ones <10; ones++)
            matrix[tens][ones]=vector[(10*tens)+ones]; //(10*tens)+ones = the absoulte index of the vector
    Hope this helps!
Message Edited by Dustin D on 06-15-2010 12:05 PM
Dustin D
Message 12 of 13
(984 Views)
Hi Dustin,
in my contribution to this problem I was trying to suggest that readable code is a valuable aspect - trying to avoid calling a vector 'matrix'... In that sense your sample code
is not exactly what I had in mind Smiley Wink
Message 13 of 13
(968 Views)
