LabWindows/CVI
version control
I've had problems with some, not all, .uir files in CVS(version control). It is flagged as a binary(not ascii), when it goes in the repositry. But when i check the project/update the project, Labwindows says the file is corrupted. Anyone experience this problem? Again this occurs on some .uir, not all.
I've have perform this test.
Started a new project, but before i commit it to the repository i make a 2nd copy.
I then committed and re-checkout the project.
I then found the corrupted .uir and did a compare with a hex editor and found nothing different.
This has stumped me.
(3,364 Views)
Hi Abui,
Have you tried changing the file attribute to text? this can be done with the command "cvs admin -kkv file".
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,351 Views)
