LabWindows/CVI
vfw32 (video for windows) put capture window into a panel?
Hey there,
I'm using the vf32.lib (+gdi32.lib) to connect a webcam to cvi. I use the command:
capCreateCaptureWindow("live capture", WS_POPUP|WS_CAPTION, 0, 0, WIDTH, HEIGHT, 0, 0)
to create a capture window. But its a popup window. I want to integrate the webcam preview into a canvas or something else on my panel in CVI. Is there any change to do it? I tried with
capCreateCaptureWindow("live capture", WS_CHILD | WS_VISIBLE, 0, 0, WIDTH, HEIGHT, panelHandle??, 0)
but it doesnt work ^^.
(5,974 Views)
How did you retrieve the panelHandle? If you just pass in the LabWindows CVI panel handle that can't work since that is something completely different from a Windows window handle. You first need to retrieve the Windows window handle from the panelHandle with
HANDLE handle;
GetPanelAttribute (panelHandle, ATTR_SYSTEM_WINDOW_HANDLE, &handle);
Rolf Kalbermatter  My Blog
(5,943 Views)
Thanks very much 🙂 it works!!!!Smiley Very Happy
My next problem: I want to draw a transparent box over the video, because the user should choose a portion of the webcam picture that is used for image processing. In the past I drawn the a single webcam image on a canvas and the transparent box over it.
(5,931 Views)
Nachtrag:
Es hat ja bekanntlich funktioniert, jedoch so:
int WHdlVideo;
GetPanelAttribute(PHdlMain, ATTR_SYSTEM_WINDOW_HANDLE, &WHdlVideo);
und dann mit meiner Kamer Library (TheImagingSource)
IC_SetHWnd(TISCam_Hdl, (HWND)WHdlVideo);
Sachen ins Bilde reinmalen mit:
PAINTSTRUCT ps;
HDC hdc = BeginPaint(hwnd, &ps);
// All painting occurs here, between BeginPaint and EndPaint.
FillRect(hdc, &ps.rcPaint, (HBRUSH) (COLOR_WINDOW+1));
EndPaint(hwnd, &ps);
usw
(4,636 Views)
