LabWindows/CVI
viByte to table of string
I am trying to write an array that is of type ViByte to table string. If I typecast then I receive 'General Protection' fault at 001B:68561DF7 error. The variable has to be of ViByte to start with. Here is the snippet of code:
int CVICALLBACK table (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
    ViByte Data[32] = {1,2,3,4,5,6,7,8,9,10,
                        11,12,13,14,15,16,17,18,19,20,
                        21,22,23,24,25,26,27,28,29,30,
                        31,NULL};
    int column_index = 1;
    int row_index = 1;
    if ( EVENT_COMMIT == event )
        for(row_index = 0; row_index <= 31; row_index++)
            SetTableCellVal (panel, control, MakePoint(column_index, (row_index+1)),
                Data+row_index);
    return 0;
Table is 5 col x 32 rows and need to write this data in the 1 column.
TIA.
CLD
(3,114 Views)
I think following statement
SetTableCellVal (panel, control, MakePoint(column_index, (row_index+1)), Data+row_index);
should be replaced by
SetTableCellVal (panel, control, MakePoint(column_index, (row_index+1)), *(Data+row_index));
Regards
(3,106 Views)
