LabWindows/CVI
viOpen returns VI_ERROR_SYSTEM_ERROR for bluetooth resources.
viOpen returns VI_ERROR_SYSTEM_ERROR for bluetooth resources. Is it possible to identify such resources, soI dont open them ? I am iterating over all the serial interfaces and when this bluetooth interface is enountered the application crashes. Is there some search string or some other NIVisa function I can use to identify such a resource ?
(3,201 Views)
The error code you listed is not very specific, this happens every time you try to open the Bluetooth resource? Can you access this Bluetooth resource in some other way? What version of NI VISA are you using? Can you run a repair or upgrade? Can you run viFindRsrc and identify the Bluetooth resources before you attempt to open them? If you can, post a screen shot of this error.
Matt
(3,185 Views)
