LabWindows/CVI
viWrite / viRead not working over Ethernet
viWrite / viRead not working over Ethernet, and this issue has appeared after the update the NI to 2019 version.
Please advise
(2,636 Views)
I have found this thread dealing with an analogous issue, and I hope it may give you useful insights.
Alessia
(2,011 Views)
I think I found the reason: In driver of some module that implemented on TCP/IP, ( in case of  improving the performance ) i send the viRead before viWrite. This sequence dose not work on 2019 version.
best regards,
Dima
(2,002 Views)
