LabWindows/CVI
visa error comport detection
HI
I am trying to do visa communtion to dectect/find  comport . I am facing issue in max(visa) to detect comport (Vertual com port).
some boards are detecting correctly in Max as comport  but some bard are dtecting but shwing yellow exclamation mark on it (see image for more clerification ).
why visa gives this type of error .please give an solution for this .
If i try use tera-term  or hyperteminal  that comport will work and i  can  able to communicate , but using visa detection i am not able to do.   getting warning and error of visa  as shown in image.
Softewares version
 1: VIsa :15.0
 2: MAx:15.0
 3: Labwindow/CVI
Message 1 of 9
(5,373 Views)
Hi, I normally use the code provided by Martin without problems: you may want to look at it.
Message 2 of 9
(5,360 Views)
HI,
Sorry i didn't get you .:)
Message 3 of 9
(5,351 Views)
Instead of using Visa, I am using LocateCom function provided by Martin Saxon, this way:
int		r, nports, portList[16] = { 0 };
// List serial ports in the system
nports = LocateCom ("", portList, 16);
for (r = 0; r < nports; r++) {
	DebugPrintf ("COM%d", portList[r]);
This code lists in debug output window all serial ports existing in the system.
Note: you need to #include <windows.h> in your code and to add SetupAPI.lib to the project.
Message 4 of 9
(5,346 Views)
hi,
Thank you for your reply .
I tried with COm loactor . In my PC COM 5,6 and 7 conneted , but in comloactor its showing only 6 and 7  , comport 5 is not detecting .
Message 5 of 9
(5,342 Views)
I personally use the function with native motherboard ports as well as several USB-to-serial adapters and Moxa NPort Ethernet-to-serial devices without problems. Is your COM5 port some special kind of device?
Message 6 of 9
(5,339 Views)
hi,
yes, its vertual COM poart. And its wokking by using  hyperterminal and tera-term .
Message 7 of 9
(5,337 Views)
A virtual com port on top of which hardware?
Maybe trying to update its driver can fix the situation.
Message 8 of 9
(5,330 Views)
no not bale to fix it
i dont konw what exactly habpaing . Using teraterm its woeking fine  bit same port is not detecting in visa as wel as comloacte too
Message 9 of 9
(5,281 Views)
